How to correctly use midsurfaces in Nastran
enzanelli
Message 1 of 12
enzanelli
Good morning,
I have a large trailer assembly that isn't appropriate for analysis via solid elements, so I'd like to use surfaces.
My problem is that when I use the "Find Thin Bodies" feature within the in-CAD environment, the midsurfaces of the different plates are separated by half of the plate thickness.
My question is: what is the correct procedure for bonding all of these disconnected midsurfaces? Am I going to have to go in and manually bond all of these plates? Should I instead prepare a derived surface model outside of the in-CAD environment specifically for analysis?
Thank you.
Replies (11)
Message 2 of 12
Roelof.Feijen
Hello @enzanelli ,
I've seen people struggle with midsurfaces quite often. I don't even start with it anymore if it is a large complex model. My advice: make a surfaces model. I always say, you have a model that you use for production drawings and a model for FEA analysis. These are not the same. Some engineering managers aren't happy when I tell their employees that, but they've probably never done FEA analysis either. Another saying: one analysis is not an analysis, it all starts after you get the first analysis results.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Message 3 of 12
enzanelli
Thank you for the input and advice. I think it's very true that the complexity of these studies is underrated.
As for the surface model, I derived a shell model from my solid, but when I open this new shell in Nastran, I cannot create any idealizations using the shells.
What should be the workflow here?
Message 4 of 12
darrenlovesmusic
enzanelli, Create a surface model from the get-go. Best workflow for me, since I work extensively with thin walled structures. However, if you need to modify the structure frequently, you must design the model parametrically to save time.
Message 5 of 12
Roelof.Feijen
Hello @enzanelli ,
Please share the surface model and I will have a look.
Roelof Feijen
Message 6 of 12
enzanelli
Hi @Roelof.Feijen , attached you'll find the surface model I extracted from the solid. I used the thicken/offset tool to build the midplanes and then extended the surfaces such that they'd all touch. I'm unable to do anything with this in Nastran.
Thank you in advance!
Message 7 of 12
Roelof.Feijen
Hello @enzanelli ,
When you use the Midsurfaces or Surface Offset command, Shell idealizations are automatically generated.
In this case you need to setup the Shell Idealization yourself. The picture below should give you enough guidance, I hope. Otherwise have a look at this tutorial.
Roelof Feijen
Message 8 of 12
enzanelli
Thank you @Roelof.Feijen this allowed me to make my idealizations. My follow up question is do I now need to use cotoniuous meshing to bond the surfaces? I'm trying to run the simualtion and I'm getting 2 errors: 1) the auto mesher cannot create a mesh using continuous meshing and 2) stiffness error when trying to run the simulation.
Thank you in advance.
Message 9 of 12
Roelof.Feijen
Hello @enzanelli ,
If everything is bonded, I would suggest to use the Solver contact with the Offset Bonded contact type. Use a appropriate max activation distance. A simple rule of thumb in this case for the max activation distance is 1.2 x the distance (openings) between the surfaces.
The Offset Bonded contact will connect 6 dof (translational and rotational), while a Bonded Contact will connect 3 dof (only translational). A Bonded Contact with shell elements will result in a hinge effect. I don't think this is what you want.
Roelof Feijen
Message 10 of 12
enzanelli
Yes, the entire weldment should be bonded together. Are you suggesting that I have to manually add the (offset) bonds between all of the surfaces? Or do I only need to manually bond the surfaces that are not touching?
Message 11 of 12
Roelof.Feijen
No, with the Solver Contact you can specify regions on which the Solver Contact should be applied, but if you don’t specify any region, it will be applied to the whole model. There’s no need to select a anything. The Solver Contact can also be used in combination with Manual Contacts. The Solver Contact will not create extra contact elements if Manual Contacts are specified between two surfaces/edges.
Roelof Feijen
Message 12 of 12
Roelof.Feijen
You might also be interested in this article.
Roelof Feijen
