Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Godmorning,
i have a question about the workflow that Nastran_in_cad use about multiaxial fatigue analisys. If i have a force or a torque with variations on time history, the software follow a workfolw like the pictures?
if have a torque like this picture, and i insert the all number in the torque's table: ( torque from real measure)
1) The software perform in automatic a Rainflow countin and produce an stress range histogram?
2) Nastran use a plamgren-miner's rule's to perform a fatigue life estimations?
Solved by John_Holtz. Go to Solution.
Hi @pizze
The answer to question 1) is that is uses a rainflow method, so I assume it uses a stress histogram (like the next step in your workflow).
The answer to question 2) is yes, the analysis uses the Palmgren Miner.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Thanks @John_Holtz for the answer, and I thank you personally for your wonderful work about: Durability 101.
