Error 5004
Error 5004
Error 5004
I am trying to do my simulation in Nastran in-cad in Inventor and getting fatal error E5004. Can you help to find out me where I am going wrong??
Roelof.Feijen
If you are sure you have contraint your model properly try a smaller mesh size.
Most of the time this solves the issue if every part in your model cannot move.
Otherwise try to determine the parts that are causing this error by performing a modal analysis. See this article for more information about this error
https://knowledge.autodesk.com/support/nastran-in-cad/troubleshooting/caas/sfdcarticles/sfdcarticles...
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
I did after that I got E5023 error and Nastran automatically shutdown and showed your report page.
Roelof.Feijen
Can you tell us a little bit more about your analysis? What is it about?
Roelof Feijen
Max.H.Pour
Try to redefine "Max Activation Distance" in surface contact>contact data>Max activation distance. Usually this happens when max activation distance is lesser than the actual gap between parts considering the mesh size.
Max H.
