create a beam element along an axis
julioorozco292
julioorozco292
hi. practicing with the PDF Autodesk Nastran in-CAD, cant créate a beam as the exercise ask to solve properly.Boceto.png
ill thank a lot if someone can help me to solve the doubt.
Hello Julio,
what you're asking for is quite easy.
I've attach a model.
Basically you create a part and a skecth. In your case I've created a 10 in segment and then I've patterned it. I've done 10 segments with 10 inch spacing. In your case you'll have to pattern 30 instances.
Then you create a new beam idealization by choosing your cross section:
Apply the load and the fixed restraint, and this is result:
julioorozco292
thanks you so much. you solve my doubt
