Contacts and constraints in rotating assembly analysis
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have this assembly, where a motor in the middle rotates 10 degrees about the x-axis clockwise and therefore rotates the "fins" (The pin on the pushrod can slide in and out). I would like to find the contact forces between the parts. Right now it is run as a "linear static" until I get it to show results, then it will be made as quasi-static analysis. The only force counteracting is the friction between all the contact points. I have set all these points as seperation contacts with a coefficient of friciton.
I have constrained the backside of the brackets in all directions. And the face of the "motor" in the middle is constrained so it can only rotate about the X-axis. And the faces of the "pushrod" where they connect to the motor threads are constrained in the z-direction and rotation about y- and z-axis.
(Coordinate system is seen on image #3 by the way)
Now to the problem:
These are the errors I get when running the simulation, and the results show 0 stresses/displacement:
