Hi everybody, I'm testing the NIC contact with shell elements on midsurfaces.
Does someone know if NIC take in account the thickness of shell during the contact solution?
or in other words, do shell elements become in contact only when their midplane intersect?
I am testing two simple alluminium cantilever beams (2mm thick, 45mm wide and 100mm long), with a 2.5mm gap between them (see attached picture).
When loaded, the upper beam should bend, cover the 2,5mm gap, touch the lower one, and then both beams should bend together.
If I solve the model with 3D tetra elements and a manual separation contact (max activation distance is set to 3mm > 2.5 gap) it works fine, even in a linear static analysis.
In a Non linear analysis I can follow up the evolution of the contact solution, the touching happens at 90% of my load, and get a final result very similar to the linear analysis.
But, when I try with midsurfaces and 2D shell elements, the separation contact does not work, and the upper beam bends trough the lower one likewise when the contact is not active!
It happens with both linear or non linear analysis, with both linear or parabolic shell elements, and even if I increase the max activation distance to 5mm > 4.5 mm gap between the midsurfaces.
I also tryed with different mesh size, or increasing the load (so the upper beam bends more than the 4.5mm midsurfaces gap) without any result.
in 3D case the contact set up is the following:
the bottom surface of the upper beam is the slave surface
the top surface of the lower beam is the master surface
surface to surface
contact type: separation
unsymmetric penetration
max activation distance actived and set to 3mm (>2.5mm gap bewteen solid)
default values for all other data
in 2D case the contact set up is the following:
the upper mid-surface is the slave surface
the lower mid-surface is the master surface
surface to surface
max activation distance actived and set to 5mm (>4.5mm gap between midsurfaces)
Note that if I switch the 2D contact to a bonded contatc, it does not work with max activation distance set to 3mm, but works fine with 5mm
I attach my test model in the zip file.
I'm using NIC 2018.0.1.189 (with hotfix1). I had to downgrade to this version beacuse the latest 2018.2 always crash.
