Hello!
I need some help cause im out of options here!
1) Im getting a error while changing the mesh size, from let say 50 to 10 mm. For 50 mm and 100 mm it works for a modal and a static analyse.
Is this an indication of what? Arent lines connected? I used split like everywhere i can find a possible error. And investigating a modal and a static anaylses, i cant find any loose ends.
2) I also getting an error when trying to change idealization from current to rigid for some reason. First i thought it was due to having different centroids defined for the joining beams, but it wasnt. See picture and attatched model.
Thanks in advance, best regards,
Daniel
