Hi Jura,
You are missing two things:
- What direction is defined as a positive shear or positive moment result. Nothing discussed so far provides this information. (Hint: they are not necessarily in the direction of the positive axis.)
- What direction is the diagram drawn in. (Hint: this is undocumented.)
For 1., the definition of positive shear and positive moment, that is given in the documentation for CBAR. I have marked up the figures from that page and used 1-2-3 for the local beam axes to avoid confusion with global X-Y-Z directions.
Based on the figure, the following table of results can be used to understand what direction the shear (V) and moment (M) results are in at each end of the element.
Result
End A
End B
Shear (V) in 2
+V in opposite direction as 2
-V in same direction as 2
+V in same direction as 2
-V in opposite direction as 2
Shear (V) in 3
+V in opposite direction as 3
-V in same direction as 3
+V in same direction as 3
-V in opposite direction as 3
Moment (M) about 2
(right-hand rule at A)
+M in same direction about 2
-M in opposite direction about 2
+M in opposite direction about 2
-M in same direction about 2
Moment (M) about 3
(right-hand rule at B)
+M in opposite direction about 3
-M in same direction about 3
+M in same direction about 3
-M in opposite direction about 3
For 2, the diagrams, it is hard to know if they are right or wrong, logically or illogically designed. There are 4 options for the plane that the diagrams are drawn in (Auto, X, Y, Z) but what is unknown is which direction in the plane is used for a positive result. Based on your results and my results, there is a difference in how they are drawn. (I plotted my diagram using the "Z-Dir" plot orientation. I'm guessing that you diagrams were created using the "Auto" option. (What is consistent is a + result is shown in the same direction for both graphs. You will have a hard time convincing anyone that a + value should be "up" in one graph but "down" in another graph.)
In summary, the shear force and moment values are correct in all cases based on the definition in the table. The diagrams are consistent in that a positive value is drawn in the same direction in both the shear and moment diagrams. This does not agree with the engineering drawings because the definition of positive and negative are different: the engineering diagram has one positive (shear) and one negative (moment) where as Nastran has both values positive.
John
John Holtz, P.E. Global Product Support
Autodesk, Inc. If not provided already, be sure to indicate the version of Inventor Nastran you are using!"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
