Update layers from template file (continued)
machiel.veldkamp
machiel.veldkamp
Hi!
I posted THIS yersterday. I figured out how to copy allmost all information from new template to old drawings but I'm now stuck on something new.
Layers!
Wrong coloursWrong colours
This is a screengrab of an old drawing that I need to convert.
Now. I have this code:
SyntaxEditor Code Snippet
Sub Main
	If ThisDoc.Document.DocumentType <> kDrawingDocumentObject Then
		MsgBox("This rule may only be run on drawing documents!",vbOKOnly,"Update Everything")
		Exit Sub
	Dim oPrompt As String
	oPrompt = MsgBox("Update Titleblocks and Styles?", vbYesNo, "Update Everything")
	Select Case oPrompt
		Case vbNo
			Exit Sub
		Case vbYes
			ImportTemplateItems() 'Copy all stuf over from the Template file.
				'MessageBox.Show("Import OK", "Title")
			UpdatePartslist()
				'MessageBox.Show("Partslist OK", "Title")
			ReplaceTitleBlock() 'Replace the current Titleblock with the new Titleblock on all sheets.
				'MessageBox.Show("TitleBlock OK", "Title")
			SetActiveStyle() 'Set the Relco Global Style as active.
				'MessageBox.Show("Set Active Style OK", "Title")
			PurgeStyles()
				'MessageBox.Show("PurgeStyle", "Title")
			DimensionUpdates()
				'MessageBox.Show("Change Dim OK", "Title")
			SheetColor()
	End Select
End Sub
Sub ImportTemplateItems()
	Dim oTargetDoc, oSourceDoc As DrawingDocument
	Dim oTBdef As TitleBlockDefinition
	Dim oTBdefs As TitleBlockDefinitions
	Dim oBorderDef As BorderDefinition
	Dim oBorderDefs As BorderDefinitions
	Dim oSymbol As SketchedSymbolDefinition
	Dim oSymbols As SketchedSymbolDefinitions
	oTargetDoc = ThisDrawing.Document
	oSourceDoc = ThisApplication.Documents.Open("C:\Relco\Vault\CAD Standards\Inventor\RELCO Global Templates\Standard.dwg", True)
	'oTargetDoc.StylesManager.ActiveStandardStyle.UpdateFromGlobal 'TURNED OF BECAUSE OF CONFLICT. Why is this broken?
	oTBdefs = oSourceDoc.TitleBlockDefinitions
	oBorderDefs = oSourceDoc.BorderDefinitions
	oSymbols = oSourceDoc.SketchedSymbolDefinitions
	For Each oTBdef In oTBdefs
		Try
			If oTBdef.Name = "RELCO Global Rev 0" Then 'Make this string your new TitleBlock name
				oTBdef.CopyTo(oTargetDoc, True)
		Catch
			MsgBox("Unknown error in copy title block for " & Chr(34) & oTBdef.Name & Chr(34),vbOKOnly,"Error")
		End Try
	Next
	For Each oBorderDef In oBorderDefs
		Try
			If oBorderDef.Name <> "Default Border" Then
				oBorderDef.CopyTo(oTargetDoc, True)
		Catch
			MsgBox("Unknown error in copy border definition for " & Chr(34) & oBorderDef.Name & Chr(34),vbOKOnly,"Error")
		End Try
	Next
	For Each oSymbol In oSymbols
		Try
			oSymbol.CopyTo(oTargetDoc, True)
		Catch
			MsgBox("Unknown error in copy sketched symbol for " & Chr(34) & oSymbol.Name & Chr(34),vbOKOnly,"Error")
		End Try
	Next
	oSourceDoc.Close()
End Sub
Sub ReplaceTitleBlock()
	Dim i As Integer
	'Replace Titleblock
	Dim oTitle0 As String
	oTitle0 = "Relco Global Rev 0" 'This should be the New Titleblock
	' Set a reference to the drawing document.
	' This assumes a drawing document is active.
	Dim oDrawDoc As DrawingDocument
	oDrawDoc = ThisApplication.ActiveDocument
	' Obtain a reference to the desired border defintion.
	Dim oTitleBlockDef As TitleBlockDefinition
	oTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item(oTitle0)
	Dim oSheet As Sheet
	'Count the number of total sheets
	Dim SheetCount As Integer
	SheetCount = oDrawDoc.Sheets.Count
	If (oDrawDoc.Sheets.Count > 0) Then 							'Execute if >1 sheets
		For Each s In oDrawDoc.Sheets
			s.Activate			'Activate sheet
			oSheet = oDrawDoc.ActiveSheet
			' Check to see if the sheet already has the correct title block and delete it if it doesn't.
			If Not oSheet.TitleBlock Is oTitle0 Then
				oSheet.TitleBlock.Delete
			Dim oTitleBlock As TitleBlock
			oTitleBlock = oSheet.AddTitleBlock(oTitleBlockDef)
		Next
	Else
		MessageBox.Show("There is only 1 Sheet. Make more sheets and come back", "Nothing to do")
End Sub
Sub PurgeStyles()
	Dim oStyles
	oStyles = oDrawDoc.StylesManager
	Dim noneleft As Boolean
	noneleft = True
	Dim ostyle As Style
	Do While (noneleft)
		noneleft = False
		For Each ostyle In oStyles.Styles
			If (ostyle.StyleLocation = "51202") And (ostyle.InUse = False) Then
				ostyle.Delete
				noneleft = True
		Next
	Loop
End Sub
Sub SetActiveStyle()
 	Const kStandardName = "RELCO Global" ' This is the name of the Style Standard
    Const kObjDefaultsName = "Relco Global Defaults"  'This is the name of the Object Standard
    Dim oDoc As DrawingDocument
    'On Error Resume Next
    oDoc = ThisApplication.ActiveDocument
    Dim oStylesMgr As DrawingStylesManager
    oStylesMgr = oDoc.StylesManager
    Dim oStandard As DrawingStandardStyle
    oStandard = oStylesMgr.StandardStyles.Item(kStandardName)
    If oStandard Is Nothing Then
       oStandard = oStylesMgr.StandardStyles.Item(1).Copy(kStandardName)
	oStylesMgr.ActiveStandardStyle = oStandard
End Sub
Private Sub DimensionUpdates()
	Dim oDim As GeneralDimension
	Dim oDimStyle As DrawingStandardStyle
	Dim oSheet As Sheet
	oDimStyle = oDoc.StylesManager.ActiveStandardStyle
	Dim oBalloon As Balloon
	For Each oSheet In oDoc.Sheets
		For Each oDim In oSheet.DrawingDimensions
			Try
				If oDim.Style.Name <> oDimStyle.ActiveObjectDefaults.AngularDimensionStyle.Name Then
					oDim.Style = oDimStyle.ActiveObjectDefaults.AngularDimensionStyle
				If oDim.Style.Name <> oDimStyle.ActiveObjectDefaults.LinearDimensionLayer.Name Then
					'oDim.Style = oDimStyle.ActiveObjectDefaults.LinearDimensionLayer
				If oDim.Style.Name <> oDimStyle.ActiveObjectDefaults.BaselineDimensionStyle.Name Then
					oDim.Style = oDimStyle.ActiveObjectDefaults.BaselineDimensionStyle
				If oDim.Style.Name <> oDimStyle.ActiveObjectDefaults.LinearDimensionStyle.Name Then
					oDim.Style = oDimStyle.ActiveObjectDefaults.LinearDimensionStyle
				If oDim.Style.Name <> oDimStyle.ActiveObjectDefaults.DiameterDimensionStyle.Name Then
					oDim.Style = oDimStyle.ActiveObjectDefaults.DiameterDimensionStyle
			Catch Ex As Exception
				MessageBox.Show("Error. Ask Machiel What's up", "Title")
			End Try
		Next
		For Each oBalloon In oSheet.Balloons
			If oBalloon.Style.Name <> oDimStyle.ActiveObjectDefaults.BalloonStyle.Name Then
                oBalloon.Style = oDimStyle.ActiveObjectDefaults.BalloonStyle
        Next
	Next
End Sub
Sub UpdatePartslist()
    Dim oStyleMgr As DrawingStylesManager
    oStyleMgr = oDoc.StylesManager
    Dim oPartListStyle As PartsListStyle
    oPartListStyle = oStyleMgr.PartsListStyles.Item("RELCO Global Parts List")
    Dim oSheet As Sheet
    Dim oPartsList As PartsList
		For Each oPartsList In oSheet.PartsLists
			oPartsList.Style = oPartListStyle
	    Next
	Next
End Sub
Sub SheetColor()
Dim oSheetSettings As SheetSettings
oSheetSettings = oDoc.SheetSettings
Dim oColor As Color
oColor = ThisApplication.TransientObjects.CreateColor(237, 237, 214)
oSheetSettings.SheetColor = oColor
End Sub
So!
In DimensionUpdates() I tried getting the Layername from the template and put it in the new drawing but it error's out and it doesn;t seem to work!
Are you supposed to handle layers differently then Styles?
What am I doing wrong here?
I can't find much online.  Help?
___________________________
machiel.veldkamp
Ok. Dimensions were easy enough.
If oDim.Layer.Name <> oDimStyle.ActiveObjectDefaults.LinearDimensionLayer.Name Then
	oDim.Layer = oDimStyle.ActiveObjectDefaults.LinearDimensionLayer
Now on to drawingviews. Those seem harder?
