Edit filename of iAssembly Table Member in ilogic
danmorick
danmorick
Can anyone show me how to edit the member name in an iassembly table using code?  The Part Number and Description iproperties are easy to handle.  But I am stuck on how to access the member name and edit it.  I guessed at some methods, but keep getting errors.
Thanks.
-Dan
xiaodong_liang
Autodesk Support
Autodesk Support
Similar to iPart, the iAssembly is edited through the corresponding Excel table. Here is a small demo on how to create which could be start for you.
Public Sub CreateiAssemblyFactory()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim odef As AssemblyComponentDefinition
    Set odef = oDoc.ComponentDefinition
    Dim oFactory As iAssemblyFactory
    Set oFactory = odef.CreateFactory
    Dim oWorkSheet As WorkSheet
    Set oWorkSheet = oFactory.ExcelWorkSheet
    Dim oCells As Range
    Set oCells = oWorkSheet.Cells
    ' Columns...
    oCells.Item(1, 2) = "HANDLE CAP:1:Include/Exclude"
    oCells.Item(1, 3) = "HANDLE CAP:2:Include/Exclude"
    oCells.Item(1, 4) = "LEVER ARM:1:Include/Exclude"
    oCells.Item(1, 5) = "Arbor_Frame:1:Grounding Status"
    oCells.Item(1, 6) = "d75"
    oCells.Item(1, 7) = "d92"
    ' Row 1 values...
    oCells.Item(2, 1) = "Arbor_Press-01"
    oCells.Item(2, 2) = "Include"
    oCells.Item(2, 3) = "Include"
    oCells.Item(2, 4) = "Include"
    oCells.Item(2, 5) = "Grounded"
    oCells.Item(2, 6) = "0.0 in"
    oCells.Item(2, 7) = "180.00000"
    ' Row 2 values...
    oCells.Item(3, 1) = "Arbor_Press-02"
    oCells.Item(3, 2) = "Include"
    oCells.Item(3, 3) = "Include"
    oCells.Item(3, 4) = "Include"
    oCells.Item(3, 5) = "Grounded"
    oCells.Item(3, 6) = "0.5 in"
    oCells.Item(3, 7) = "90.00000"
    ' Row 3 values...
    oCells.Item(4, 1) = "Arbor_Press-03"
    oCells.Item(4, 2) = "Exclude"
    oCells.Item(4, 3) = "Exclude"
    oCells.Item(4, 4) = "Exclude"
    oCells.Item(4, 5) = "Ungrounded"
    oCells.Item(4, 6) = "0.0 in"
    oCells.Item(4, 7) = "180.00000"
    Dim oWB As WorkBook
    Set oWB = oWorkSheet.Parent
    oWB.Save
    oWB.Close
End Sub
danmorick
Xiaodong,
Thanks very much for that.  Unfortunately, I have my code as ilogic, not straight VB.NET.  So when I run this I get an error,
"Type 'WorkSheet' is not defined."  Is there a way that you can think of to do this in the ilogic environment?  My member name is always a formula of Part Number and Description iproperties, both of which I have in my table.
My alternative, I suppose, is to convert my code to pure vb.net and then proceed...
-Dan
xiaodong_liang
Autodesk Support
Autodesk Support
you could declare the objects of Excel without type. I believe iLogic has import Excel reference, that is why there are some methods under the category Excel. The iLogic code below works well at my side.
    Dim oWorkSheet
    Dim oCells
    ' Columns...
    ' Row 1 values...
    ' Row 2 values...
    ' Row 3 values...
    Dim oWB
    oWB.Save
    oWB.Close
danmorick
Excellent!  Yes, this is working for me.  Thanks so much for the assistance.
erichter
This method works great to change the Excel table, but I am trying to use this to change an entire column of the table (including the active row), and iLogic will not update the model based on the active row of the table. Furthermore, Inventor seems to want to override the table's active row based on the current model state. Unless I open the Excel table again while answering "no" to the prompt to update the table, then save and close the table and answer "yes" to the prompt to update the model. Do you know of a way to force the table to update the model or a workaround that will achieve the same effect?
For i = 2 to oFactory.TableRows.Count + 1
oCells.Item(i, 3) = "Text to replace"
Next
