Switching imported parameters to user defined parameters through iLogic
Hello Inventor Forum
I have linked parameters in multiple documents and would like to delete the link through an iLogic rule. The imported parameters are supposed to become user defined parameters without any external references, much like when using the manual "delete folder" command in the parameters window. I do not care for the exportparameter flag in the originating file, unless the solution necessitates changing it.
Is there an easy way to do this? I can't seem to find the right function. I'm running Inventor 2016 SP1.
b_sharanraj
Hi @Anonymous
Try the below Code 🙂
Option Explicit
Sub Main()
Dim Param As Parameter
Dim Param_Expression As String
Dim Param_Units As String
Dim Usr_Params As UserParameters
Dim Der_Param_Table As DerivedParameterTable
Dim i As Integer
i = 1
For Each Der_Param_Table In ThisApplication.ActiveDocument.ComponentDefinition.Parameters.DerivedParameterTables
For Each Param In ThisApplication.ActiveDocument.ComponentDefinition.Parameters.DerivedParameterTables.Item(i).DerivedParameters
Param_Expression = AlphaNumericOnly(Param.Expression)
MsgBox(Param_Expression)
Param_Units = Param.Units
Param = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters.AddByExpression("Temp_" & Param.Name, Param_Expression, Param_Units)
Next
i = i + 1
Next
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.DerivedParameterTables.Item(1).Delete
Next
For Each Param In ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
If InStr(Param.Name, "Temp_") = 1 Then
Param.Name = Right(Param.Name, Len(Param.Name) - 5)
Next
End Sub
Function AlphaNumericOnly(strSource As String) As String
    Dim i As Integer
    Dim strResult As String
    For i = 1 To Len(strSource)
        Select Case Asc(Mid(strSource, i, 1))
            Case 46, 48 To 57:
                strResult = strResult & Mid(strSource, i, 1)
        End Select
    Next
    AlphaNumericOnly = strResult
End Function
Regards
B.Sharan Raj
Martin-Winkler-Consulting
Hi Chris,
if you only want to delete the derived tables try this:
Option Explicit
Sub Main()
Dim oPart As PartDocument
    oPart = ThisApplication.ActiveDocument
Dim oParams As Parameters
Dim oDevParam As DerivedParameter
'Get Parameter Tables
    oParams = oPart.ComponentDefinition.Parameters
	'check id there is a derived table
    If oParams.DerivedParameterTables.Count > 0 Then
	 For Each oDevTable In oParams.DerivedParameterTables
'Kopie Parameters to User Parameters '! This not necessary if the derived parameters are used in the model parameters ' then they will be copied automatically For Each oDevParam in oDevTable.DerivedParameters 'Copy Method from B.Sharan Raj Next If oDevTable.HasReferenceComponent = False Then 'delete all linked tables oDevTable.Delete End If Next End If End Sub
When derived parameters are used in model parameters inventor copies them automatically into the user parameters when the derived table is deleted.
Otherwise they are lost.
If you want to copy all of the derived parameters to user parameters look at the code from B.Sharan Raj.
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
Hi B.Sharan Raj, Hi Martin
I've tested both rules and they seem to do exactly what I need. In retrospect I see that my description was somewhat vague, since, I only need the parameters that are actually being used in the active document. Thus, in my current case, the second one is the one I'm going to be using. The first one however will surely come in handy at a later point in time.
Thank you very much!
