Rectangular Pattern using a SketchLine for direction
Raider_71
Raider_71
Hi I am having an issue trying to create a simple rectangular pattern by using a SketchLine as the direction indicator. The routine works if I use an edge or WorkAxis but not a sketchline.
Here is my code:
    Private Sub BtnPatternFeature_Click(sender As Object, e As EventArgs) Handles BtnPatternFeature.Click
        Dim oDoc As Inventor.PartDocument = oApp.ActiveDocument
        Dim oCompdef As Inventor.PartComponentDefinition = oDoc.ComponentDefinition
        Dim oFeatures As PartFeatures = oCompdef.Features
        Dim OselectSet As Inventor.SelectSet = oDoc.SelectSet
        Dim oSketchLine As SketchLine = OselectSet.Item(1)
        Dim oFeature As Inventor.PartFeature = oFeatures.Item(2)
        Dim oFeatObjCollection As Inventor.ObjectCollection = oApp.TransientObjects.CreateObjectCollection
        oFeatObjCollection.Add(oFeature)
        Dim Count As Object = 3
        Dim oSpacing As Object = 2
        Dim oRPFD As RectangularPatternFeatureDefinition
        Dim oGeom As GeometryIntent = oCompdef.CreateGeometryIntent(oSketchLine)
        oRPFD = oCompdef.Features.RectangularPatternFeatures.CreateDefinition(oFeatObjCollection, oGeom, True, Count, oSpacing)
        oCompdef.Features.RectangularPatternFeatures.AddByDefinition(oRPFD)
    End Sub
I have tried using just the SketchLine and also by creating a GeometryIntent but neither worked.
Any pointers?
Thanks chaps!
wgraham
Instead of a geometry intent, try using a path.
Dim oGeom as Path = oCompDef.Features.CreatePath(oSketchLine)
It works on some of my older code.
William
Raider_71
Thanks that's working like a charm!
The Geometry intent had me going in the wrong direction there...
I saw the path option but thought it was only for patterning along a 3D path...
