Inventor Browser / Workplanes or WorkAxis
How can i visible the Workplane or Workaxis from a active Part from a Assembly
==> see Printscreen Tuned Pipe
with this Code i can set it to true because i set in the Part not in the corrent View ?
Dim oWorkAxisSwitch As Boolean
Private Sub test()
Dim m_inventorApplication As Inventor.Application
Set m_inventorApplication = ThisApplication
Dim oDoc As Inventor.Document
Set oDoc = m_inventorApplication.ActiveDocument
Dim oEditDoc As Inventor.Document
Set oEditDoc = m_inventorApplication.ActiveEditDocument
Dim oSelect As Inventor.SelectSet
Set oSelect = oEditDoc.SelectSet
oWorkAxisSwitch = True
For Each BrowserParentItem In oEditDoc.BrowserPanes.Item(2).TopNode.BrowserNodes
If Not BrowserParentItem.NativeObject Is Nothing Then
If BrowserParentItem.NativeObject.Type = kWorkAxisObject Then 'Like "83891360" Then
BrowserParentItem.NativeObject.Visible = oWorkAxisSwitch
Next
If oWorkAxisSwitch = True Then oWorkAxisSwitch = False: GoTo Ende
If oWorkAxisSwitch = False Then oWorkAxisSwitch = True: GoTo Ende
Ende:
oEditDoc.Update
End Sub
thx for help
Mario
Hi Mario,
You just need to define the workplanes and workaxis, then make it visible.
Your modified code is here........
Private Sub test()
'First Wplane
Dim Wplane As WorkPlane
Set Wplane = oEditDoc.ComponentDefinition.WorkPlanes.Item(1)
Wplane.Visible = True
'First WorkAxis
Dim WAxis As WorkAxis
Set WAxis = oEditDoc.ComponentDefinition.WorkAxes.Item(1)
WAxis.Visible = True
'Your Code Here
Ende:
oEditDoc.Update
End Sub
Digvijay
