iLogic Parameter Multi-Value sorted list
hperison
hperison
I have been attempting to have a sorted list within my User Parameters
image.png or image.png.  However, every method that I have tries so far becomes
a jumbled mess as shown.  How can I have this multi-value lists display in the proper logical order (smallest to largest).
hperison
Add Numeric Multi-Value list worked. I thought that the value listed as a Fraction would have been a string value, but it worked in a numeric list.
hperison
After some further testing, I find that this method is a little closer to being correct but not quite.
image.png.  Any suggestions to achieving the correct result or nobody really worried about this in their customization routines?
chandra.shekar.g
Autodesk Support
Autodesk Support
@hperison,
Hoping that below iLogic code may be helpful.
Dim arr As ArrayList
arr = MultiValue.List("Name of multivalue parameter")
arr.Sort()
MultiValue.List("Name of multivalue parameter") =  arr
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
rob
Yep, that helped me out, thanks!
IV Pro 2020.2
