iLogic code for Parts List selection
mtmarchant
Message 1 of 9
mtmarchant
I have been piecing together a bit of code, trying to accomplish a few goals:
 *Note: This is all occurring with an assembly drawing that utilizes multiple parts list, assemblies, parts, and drawing views.
1.) Automatically setting view labels - I want to pull both parts list data and iproperty data to be used in the view label. I have figured out the code to this point and it is working as intended.
2.) This plays into goal number 1. I am pulling the quantity data directly from the parts list. This works great, however, we have times where we are building the same assembly, multiple times. I have played with making a multiplier column in the parts list, however this seems cumbersome to effectively modify on larger assemblies, as I have to enter in a multiplier value to each individual row. If possible, I would like to be able to have a form, wherein you enter a Total Assembly Quantity, and it maps that value you enter there to either a parameter or a new custom property, that could then be used to multiply the quantities accordingly. Here is a screenshot of basically what I am doing now:
3.) The majority of our drawings have multiple parts lists within them. The code I have so far works great - for the very first parts list found in the drawing. However, whenever I am working my way through the drawing, and have come to the next sub-assembly and it's respective parts list, the code stops working, and it will not update the view labels. This is the one that I have been stumped on the most, as, like I said, I have mostly pieced my current code together using other forum posts and such.
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheets As Sheets
oSheets = oDrawDoc.Sheets
Dim oSheet As Sheet'Inventor.Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oPartsLists As PartsLists
Dim oPartsList As PartsList
For Each oSheet In oSheets
    'declare the PartsLists
    oPartsLists = oSheet.PartsLists
            'try and get the parts list from the table of this sheet
            Try
                'this doesn't work when you have a material list like on frame drawings
                'oPartsList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
                'place a parts list on the drawing and search for it
                'rather than using an id number
                For i=1 To oPartsLists.Count
                    If oPartsLists.Item(i).Title = "PARTS LIST" Then
                        'MessageBox.Show("found table", "ilogic")
                        oPartsList = oPartsLists.Item(i)
                        Exit For
                    Else
                        'do nothing
                    End If
                Next
            Catch 'on error try and search all sheets for first found parts list
                'iterate through each sheet
                Dim j As Long
                For j = 1 To oDrawDoc.Sheets.Count
                    If oDrawDoc.Sheets.Item(j).PartsLists.Count > 0 Then Exit For
                Next
                'this doesn't work when you have other parts lists like a
                '"material list" like on frame drawing
                'oPartList = oDrawDoc.Sheets.Item(i).PartsLists.Item(1)
                'rather than using an id number to locate the first
                        Exit For
                    Else
                        'do nothing
                    End If
                Next
                'MessageBox.Show("parts list found on: " & j, "Title")
            End Try
    oViews = oSheet.DrawingViews
        'get view from user
        While True
            oView = ThisApplication.CommandManager.Pick( _
            SelectionFilterEnum.kDrawingViewFilter, "Select a View")
            'Get the full filename Of the view model
            Dim oModelFileName As String
            oModelFileName = oView.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName
            'MessageBox.Show("view model name" & oModelFileName, "Title")
            ' Iterate through the contents of the parts list.
            Dim j As Long
            For j = 1 To oPartsList.PartsListRows.Count
                ' Get the current row.
                Dim oRow As PartsListRow
                oRow = oPartsList.PartsListRows.Item(j)
                'get filename of model in row
                Dim oRowFileName As String
                Try ' try and get the full file name of the PL item
                    oRowFileName = oRow.ReferencedFiles.Item(1).FullFileName
                Catch 'on error go to next item
'                    Dim oCellValue As String
'                    oCellValue = oRow.Item("Item").Value
'                    MessageBox.Show("Error Processing item: " & oCellValue, "Title")
                    Continue For
                End Try
                'compare the filenames
                'Performs a text comparison, based on a case-insensitive text sort order
                'If strings equal returns 0
                If StrComp(oModelFileName, oRowFileName, CompareMethod.Text)=0 Then
                    'Get the value of Item from the Parts List
                    'Row name needs to be case sensitive or use 1 for first 2 for second etc.
                    oCell  = oPartsList.PartsListRows.Item(j).Item("Item")
                    'get the value of text in cell
                    Dim oItemValue As String
                    oItemValue = oCell.Value
                    'Show the view label
                    oView.ShowLabel = True
                    'format the next line
                    oStringItem = "<StyleOverride Underline='True' FontSize='0.25'> ITEM " & oItemValue & " </StyleOverride>"
					'Scale is not being utilized at this time
					'oStringScale = "<Br/><StyleOverride FontSize='0.2'>Scale <DrawingViewScale/></StyleOverride>"
					'This pulls the part number iProperty from the reference file
					oStringPNumber = "<Br/><StyleOverride Underline='False' FontSize='0.2'> P#: <Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>"
					'This pulls the revision iProperty from the reference file
					oRev = iProperties.Value(docFName,"Project","Revision Number")
					'oStringViewRev = "<StyleOVerride Underline='False' FontSize='0.2'> REV: " & oRev & " </StyleOverride>"
					'This pulls the description iProperty from the reference file
					oStringViewDesc = "<Br/><StyleOverride Underline='False' FontSize='0.2'> DESC: <Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>"
					'This pulls the material iProperty data from the reference file
					oStringViewMat = "<Br/><StyleOverride Underline='False' FontSize='0.2'> MATERIAL: <Property Document='model' PropertySet='Design Tracking Properties' Property='Material' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>MATERAIL</Property></StyleOverride>"
					'This pulls quantity data from the parts list
					oCellQuantity = oPartsList.PartsListRows.Item(j).Item("Item QTY")
					Dim oListQuantity As String
					oListQuantity = oCellQuantity.Value
					oStringListQuantity = "<Br/><StyleOverride Underline='False' FontSize='0.2'> QTY: " & oListQuantity & " </StyleOverride>"
                    'add to the view label
                    oView.Label.FormattedText =  oStringItem & oStringViewDesc & oStringPNumber & oStringViewMat & oStringListQuantity
                End If
            Next
      End While
Next
Mack Marchant - Project Engineer
Replies (8)
Message 2 of 9
A.Acheson
Here is a slightly different way of writing this. The main issues I saw was this line here
" If StrComp(oModelFileName, oRowFileName, CompareMethod.Text =0 Then"
also to activate each sheet to select the views. I turned off a few labels that I hadn't available in testing.
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheets As Sheets = oDrawDoc.Sheets
Dim j As Long
For Each oSheet in oSheets
    If oSheet.PartsLists.Count > 0 Then
		oSheet.Activate
oPartsLists = oSheet.PartsLists For Each oPartslist In oPartsLists If oPartsList.Title = "PARTS LIST" Then MessageBox.Show("found table", "ilogic")
oViews = oSheet.DrawingViews 'get view from user While True oView = ThisApplication.CommandManager.Pick( _ SelectionFilterEnum.kDrawingViewFilter, "Select a View") If oView Is Nothing Then Exit While 'Get the full filename Of the view model Dim oModelFileName As String = oView.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName 'MessageBox.Show("view model name" & oModelFileName, "Title") ' Iterate through the contents of the parts list. For j = 1 To oPartsList.PartsListRows.Count ' Get the current row. Dim oRow As PartsListRow = oPartsList.PartsListRows.Item(j) 'get filename of model in row Dim oRowFileName As String Try ' try and get the full file name of the PL item oRowFileName = oRow.ReferencedFiles.Item(1).FullFileName Catch 'on error go to next item Dim oCellValue As String = oRow.Item("Item").Value ' MessageBox.Show("Error Processing item: " & oCellValue, "Title") Continue For End Try 'compare the filenames 'Performs a text comparison, based on a case-insensitive text sort order 'If strings equal returns 0 ' If StrComp(oModelFileName, oRowFileName, CompareMethod.Text)=0 Then 'Get the value of Item from the Parts List 'Row name needs to be case sensitive or use 1 for first 2 for second etc. oCell = oPartsList.PartsListRows.Item(j).Item("Item") 'Row name needs to be case sensitive or use 1 for first 2 for second etc. 'get the value of text in cell Dim oItemValue As String = oCell.Value 'Show the view label oView.ShowLabel = True 'format the next line oStringItem = "<StyleOverride Underline='True' FontSize='0.25'> ITEM " & oItemValue & " </StyleOverride>" 'format the next line 'Scale is not being utilized at this time 'oStringScale = "<Br/><StyleOverride FontSize='0.2'>Scale <DrawingViewScale/></StyleOverride>" 'format the next line 'This pulls the part number iProperty from the reference file oStringPNumber = "<Br/><StyleOverride Underline='False' FontSize='0.2'> P#: <Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>" 'format the next line 'This pulls the revision iProperty from the reference file oRev = iProperties.Value(docFName,"Project","Revision Number") 'oStringViewRev = "<StyleOVerride Underline='False' FontSize='0.2'> REV: " & oRev & " </StyleOverride>" 'format the next line 'This pulls the description iProperty from the reference file oStringViewDesc = "<Br/><StyleOverride Underline='False' FontSize='0.2'> DESC: <Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>" 'format the next line 'This pulls the material iProperty data from the reference file oStringViewMat = "<Br/><StyleOverride Underline='False' FontSize='0.2'> MATERIAL: <Property Document='model' PropertySet='Design Tracking Properties' Property='Material' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>MATERAIL</Property></StyleOverride>" 'format the next line 'This pulls quantity data from the parts list 'oCellQuantity = oPartsList.PartsListRows.Item(j).Item("Item QTY") ' Dim oListQuantity As String ' oListQuantity = oCellQuantity.Value ' oStringListQuantity = "<Br/><StyleOverride Underline='False' FontSize='0.2'> QTY: " & oListQuantity & " </StyleOverride>" 'add to the view label oView.Label.FormattedText = oStringItem & oStringViewDesc & oStringPNumber & oStringViewMat & oStringListQuantity 'End If Next 'Partslistrowcount End While Exit For Else 'do nothing End If Next'Partslistloop End If Next 'SheetCount
Regards
Alan
Message 3 of 9
mtmarchant
This is working great to find the next parts list in the drawing, however, our parts lists and drawing views do not always end up on the same sheet. When this is the case, the drawing views will always be on the sheets that appear AFTER the sheet that contains the parts list. Is there a way to reference this parts list, that is on a different sheet, cycle through the following sheets, selecting views as needed? This may not be the ideal workflow, but I am curious nonetheless if this is possible and practical.
Message 4 of 9
A.Acheson
@mtmarchant I see now the workflow. Which is actually fairly typical and I hadn't accounted for that. My thinking is activate the sheet on each sheet, so move that line up. Then remove the move the following to a block of code just below the sheet activation (partlist count, partslist loop,partslist title check. This way you can check each sheet for a partlist and update the partslist object any time you find one.
Regards
Alan
Message 5 of 9
mtmarchant
@A.Acheson
I want to preface with a thank you, for taking time out of your day to advise and assist on this.
I'm having a hard time following. I moved the sheet activation up before the partslists if statement, so as to activate each sheet before searching for the parts list. I changed the parts list counter to -1 from 0, in an effort to try and read the sheets that do not contain a parts list. I have excluded the while statement, in an effort to try and get the code to cycle through each sheet, regardless of whether that sheet has a parts list or not. Because the while contained a line of code that looks for a parts list title, I figured that on those sheets that do not contain a parts list, that this line of code would skip past those sheets because there is not a parts list to be found on that particular sheet.
The current code cycles through the drawing, finding the sheets that contain a parts list. I believe that what I need is a way to cycle through each sheet of the drawing, update the parts list as I'm cycling through, and update drawing views as needed as I cycle through.
Dim j As Long
	'Moved sheet activation up before the IF statement
	oSheet.Activate
	'Changed > value from 0 to -1 to try and account for sheets that do not have a parts list
    If oSheet.PartsLists.Count > -1 Then
		'Disaled this sheet activation as it is being activated before the previous IF statement
		'oSheet.Activate
                MessageBox.Show("Parts List Found", "iLogic Rule")
'		        Get View From user
''While disabled in an effort to bypass the parts list title bit of code
'		        While True
					End If
		                    Continue For
		                End Try
'							oRev = iProperties.Value(docFName,"Project","Revision Number")
'		                End If
'		      End While
	           Exit For
	        Else
	            'do nothing
	        End If
        Next'Partslistloop
	End If
Next 'SheetCount
Message 6 of 9
A.Acheson
Try this one and see if it works for you.
Dim j As Long
	oSheet.Activate
	'[Set the partslist object as each one is found
		         Exit For
	        Else
	            'do nothing
	        End If
		Next'Partslistloop
	End If
	'Pause and allow sheet to change and keep selecting views
	ThisApplication.UserInterfaceManager.DoEvents
    'get view from user
    While True
		'Exit view and move to next sheet
		Try
                Continue For
            End Try
				Dim oListQuantity As String = oCellQuantity.Value
            'End If
		Catch
			MessageBox.Show("Error in partlsist cell loop", "Title")
		End Try
  End While
Next 'SheetLoop
Regards
Alan
Message 7 of 9
mtmarchant
@A.Acheson the only issue I'm having with it now is that the Item # and Quantity are referencing the last row in the parts list. I've tried comparing this code to the other old versions of code to remedy this, but I'm not finding the inconsistency that is causing this particular issue.
Message 8 of 9
A.Acheson
I switched off this line which would be the detection of the partlist row against the view referenced . This is needed to ensure the right information is being passed to the view label. Maybe check that filter is working first.
Regards
Alan
Message 9 of 9
mtmarchant
That fixed it. The code is working beautifully.
Again, thank you for your assistance on this project.
