ilogic and work plane visibility toggle conditional
sam
Message 1 of 8
sam
Hi All,
I am looking for a way to link visibility (on/off) of work plane with associated feature being active (True/False).
Any help/ideas appreciated.
regards,
Sajid Mahmood
Accepted solutions (4)
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@sam,
Try below iLogic code to toggle visibility of work plane in part document.
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oPlane As WorkPlane
oPlane = oDef.WorkPlanes.Item("Work Plane") 'Need to specify name of work plane
oPlane.Visible = False ' True for visiblity
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
sam
Hi Chander Sheker G,
Thanks for the reply. Sorry for not being very clear with the message in my intial post. I was trying to write an iLogic code to link with a form where I would be turning off those features. Problem I am facing is that I can't seem to find where to do same with planes.
Below is sample code:
SyntaxEditor Code Snippet
If Spacers = "2" Then Feature.IsActive("SpacerHoles01") = True
If Spacers = "2" Then Feature.IsActive("SpacerHoles02") = True
If Spacers = "1" Then Feature.IsActive("SpacerHoles01") = True If Spacers = "1" Then Feature.IsActive("SpacerHoles02") = False
If Spacers = "0" Then Feature.IsActive("SpacerHoles01") = False
If Spacers = "0" Then Feature.IsActive("SpacerHoles02") = False
Now these features SpacerHoles01 and SpacerHoles02 should turn on/off with their respective work planes names as Spacer1 and Spacer2.
I hope I made myself clear this time.
best regards,
Sajid Mahmood
Message 4 of 8
clutsa
i think @chandra.shekar.g had it right. Here's his code in your context.
Dim oPlane1 As WorkPlane
oPlane1 = oDef.WorkPlanes.Item("Spacer1") 'Need to specify name of work plane
Dim oPlane2 As WorkPlane
oPlane2 = oDef.WorkPlanes.Item("Spacer2") 'Need to specify name of work plane
	oPlane1.Visible = True
	oPlane2.Visible = True
Else If Spacers = "1" Then
	oPlane2.Visible = False
Else 'assume 0
	oPlane1.Visible = False
or...
Select Case Spacers
Case = "2"
Case = "1"
Case = "0"
End Select
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 5 of 8
sam
@chandra.shekar.g thank you.
@clutsa Thank you.
Message 6 of 8
sam
@clutsa I have used first rule in on of my part. Some of that part parameters are being controlled in an Assembly. After incorporating This rule in the part it gives following error in the assembly.
Any insight what does this mean?
Message 7 of 8
clutsa
The rule is running from a part document but the "active document" isn't that part anymore... try this so the rule stays focused on the document that called it
oDoc = ThisDoc.Document 'updated here
Else 'assume 0
Message 8 of 8
sam
@clutsa Worked like a charm.
Thank you so much for the help. have a good day sir.
