Hello Mr. coder convert this code to vb.net
Chandan_SharmaZ3CJW
Message 1 of 8
Chandan_SharmaZ3CJW
Sub Main
If TypeOf ThisDoc.Document Is DrawingDocument Then
Dim dwgDoc As DrawingDocument = ThisDoc.Document
For Each dwgSheet As Sheet In dwgDoc.Sheets
If dwgSheet.DrawingViews.Count > 0 Then
modelFile = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName
modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
prtNumber = modelDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(5).Value
If Not String.IsNullOrEmpty(prtNumber) Then
dwgSheet.Name = prtNumber
Next
End Sub
Replies (7)
Message 2 of 8
A.Acheson
That code looks like it will work in the ilogic environment. Are you finding an error? If so please post the error message of the more info tab. Are you trying to run this in visual studio?
Regards
Alan
Message 3 of 8
Chandan_SharmaZ3CJW
Message 4 of 8
Chandan_SharmaZ3CJW
Maybe I am not able to Declare Variable, it can be reason.
Please advise how can be solved.
Message 5 of 8
Cadkunde.nl
I think debugging should explain what is going wrong.
But on first sight:
you declare
Dim ModelFile as Partdocument
Then you say ModelFile = .FullDocumentName (which is a string, you can see that if you hoover over it with your mouse)
you are missing Dim modeldoc as Document
you are missing Dim prtNumber as String
iLogic is filling in these missing parts for you, but in visual studio that is not the case
Message 6 of 8
Chandan_SharmaZ3CJW
Sub Main
Next
End Sub
'' This is my iLogic code -Just I need to create dll file through visual studio-
so what step need to do , Please explain.
Message 7 of 8
Cadkunde.nl
Sub Main
If TypeOf g_inventorapplication.Document Is DrawingDocument Then
Dim dwgDoc As DrawingDocument = g_inventorapplication.ActiveDocument
Dim modelFile As String = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName
Dim modelDoc As Document = g_inventorapplication.Documents.Open(modelFile, False)
Dim prtNumber As String = modelDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(5).Value
Next
End Sub
Message 8 of 8
Cadkunde.nl
oh and I don't know if that line "If Type Of ..... Then" works
I would use
If g_inventorapplication.ActiveDocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
