Get the Origin Axis an edge is parallel to
dialunau
dialunau
I need to know the axis that a selected edge is parallel to. How can I do this?
Thank you in adnvance.
Curtis_Waguespack
Hi @dialunau
Something like this example should work.
I hope this helps.
Curtis
Dim oEdge As Edge = ThisApplication.CommandManager.Pick _
	(SelectionFilterEnum.kPartEdgeLinearFilter, "Select an edge")
If oEdge Is Nothing Then Exit Sub
Dim oLine As LineSegment = oEdge.Geometry
Dim oAxis As WorkAxis
For i = 1 To 3
	oAxis = ThisDoc.Document.ComponentDefinition.WorkAxes.Item(i)
	If oLine.Direction.IsParallelTo(oAxis.Line.Direction) Then MsgBox(oAxis.Name, , "iLogic")
Next
Curtis_Waguespack
Or this if you want to look at any axis ( not just the orgin axes)
For i = 1 To ThisDoc.Document.ComponentDefinition.WorkAxes.count
	If oLine.Direction.IsParallelTo(oAxis.Line.Direction) Then msg = msg & vblf & oAxis.name
Next
MsgBox(msg, , "iLogic")
CGBenner
@dialunau  Did the information provided by @Curtis_Waguespack answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
