Message 1 of 1
Feature control frame position
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm really stuck at this point. So I am looking for one help
I want to change position of feature control frame below dimension line
Public Sub H7()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oDrawingDim As DrawingDimension
Set oDrawingDim = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Select an dimension")
If oDrawingDim.DimensionType = kAlignedDimensionType Then
Call HorizontalDim(oDrawingDim)
End If
End Sub
Sub HorizontalDim(oDrawingDim As DrawingDimension)
'Set a reference to the active sheet.
Dim oSheet As Sheet
Set oSheet = oDrawingDim.Parent.Parent.ActiveSheet
' Create the feature control frame symbol with a leader
' Set a reference to the TransientGeometry object.
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
'assuming that the selection curve is linear
Dim StartPoint, EndPoint, MidPoint As Point2d
Set MidPoint = oDrawingDim.DimensionLine.MidPoint
Set StartPoint = oDrawingDim.DimensionLine.StartPoint
Set EndPoint = oDrawingDim.DimensionLine.EndPoint
Dim oLeaderPoints As ObjectCollection
Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
'Create a few leader points with same direction of text position
'elbow
If oDrawingDim.DimensionLine.StartPoint.X > oDrawingDim.Text.Origin.X Then
Call oLeaderPoints.Add(oTG.CreatePoint2d(StartPoint.X - 1.7, StartPoint.Y))
ElseIf oDrawingDim.DimensionLine.MidPoint.X = oDrawingDim.Text.Origin.X Then
Call oLeaderPoints.Add(oTG.CreatePoint2d(MidPoint.X, MidPoint.Y))
Else
Call oLeaderPoints.Add(oTG.CreatePoint2d(EndPoint.X + 1.7, EndPoint.Y))
End If
'Create an intent and add to the leader points collection.
'This is the geometry that the symbol will attach to.
Dim oGeometryIntent1 As GeometryIntent
Set oGeometryIntent1 = oSheet.CreateGeometryIntent(oDrawingDim, MidPoint)
Call oLeaderPoints.Add(oGeometryIntent1)
' Create a FeatureControlFrameRows object to define the symbol's rows
Dim oRows As FeatureControlFrameRows
Set oRows = oSheet.FeatureControlFrames.CreateFeatureControlFrameRows
' Add a row
Dim oRow As FeatureControlFrameRow
Set oRow = oRows.Add(kPosition, "Ø0.02", , "", "")
Dim oSymbol As FeatureControlFrame
Set oSymbol = oSheet.FeatureControlFrames.Add(oLeaderPoints, oRows)
End Sub
