Create drawing with existing ilogic code
randy.redekop
randy.redekop
Hello all,
Below is a code that creates a ipt file for whatever number tags i choose to. It works good but i would like to create a drawing with every part it makes with just the front face view. Ill also attach the template ipt file where it creates the parts from.  If anyone can help that would be great. Thanks
Feature.IsActive("___0") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("___1") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("___2") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("___3") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("___4") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("___5") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("___6") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("___7") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("___8") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("___9") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("__0_") = False
Feature.IsActive("__1_") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("__2_") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("__3_") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("__4_") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("__5_") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("__6_") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("__7_") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("__8_") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("__9_") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("_0__") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("_1__") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("_2__") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("_3__") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("_4__") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("_5__") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("_6__") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("_7__") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("_8__") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("0___") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("1___") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("2___") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("3___") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("4___") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("5___") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("6___") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("7___") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
Feature.IsActive("8___") = False
d35 = 0.25 in
d37 = 0.00 deg
d36 = 1 in
For i = 4 To 4
	x = i - 1
	If x = -1
	Feature.IsActive(i & "___") = True
Else
	Feature.IsActive(x & "___") = False
End If
	For z = 0 To 7
		y = z - 1
		If y = -1
		Feature.IsActive("_" & z & "__") = True
		Else
			Feature.IsActive("_" & y & "__") = False
		End If
		If z = 4
			Feature.IsActive("__0_") = True
			Feature.IsActive("___0") = True
			NewFileName = ThisDoc.Path & "\" & i & z & a & c & ".ipt"
ThisDoc.Document.SaveAs(NewFileName, True)
Else
		For a = 0 To 9
			b = a - 1
			If b= -1
					Feature.IsActive("__" & a & "_") = True
				Else
				Feature.IsActive("__" & b & "_") = False
				End If
			For c = 0 To 9
				d = c - 1
			If a = 0 And c = 0
			End If
			If d = -1
				Feature.IsActive("___" & c) = True
				Else
				Feature.IsActive("___" & d) = False
End If
			If c = 9 And a = 9
				Feature.IsActive("___" & c) = False
				Feature.IsActive("__" & a & "_") = False
			End If
			If c = 9
			End If
			Next
			Next
		End If
			Next
			Next
A.Acheson
Here is a post to a simple drawing creation. I  would suggest just run it on a part file first as its own rule. Then you can try integrate into your own rule when your happy it works.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/ilogic-create-drawing-from-part/td-p/10...
Imports System.IO
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Try 'to open the drawing
	ThisApplication.Documents.Open _
	(ThisDoc.PathAndFileName(True).Replace("ipt", "idw"))
	Return 'exit rule
Catch
End Try
'since nothing found create it...
oNewDrawing = ThisDoc.ChangeExtension(".idw")
oTemplateFolder = ThisApplication.FileOptions.TemplatesPath
Dim oList As New ArrayList
Dim Folder As New IO.DirectoryInfo(oTemplateFolder)
For Each File As IO.FileInfo In Folder.GetFiles("*.idw", IO.SearchOption.AllDirectories)
	Dim sName As New FileInfo(File.Name)
	oList.Add(sName.Name)
Next
oTemplate = InputListBox("Select a template", oList, oList(0),"iLogic", "List")
oTemplate = oTemplateFolder & oTemplate
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.Documents.Add _
(DocumentTypeEnum.kDrawingDocumentObject, oTemplate, True)
oDrawingDoc.Activate()
Dim oSheet As Sheet
oSheet = oDrawingDoc.Sheets.Item(1)
Dim oPoint As Point2d
oPoint = ThisApplication.TransientGeometry.CreatePoint2d(10, 10)
Dim oView As DrawingView
oView = oSheet.DrawingViews.AddBaseView(oDoc, oPoint, 1, _
ViewOrientationTypeEnum.kFrontViewOrientation, _
DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
oDrawingDoc.SaveAs(oNewDrawing, False)
MessageBox.Show("This new file saved as: "& oNewDrawing, "iLogic")
Regards
Alan
