Adding Welding Symbol Through API
I am automating a drawing and I had trouble accessing the welding symbol through the API. I am currently doing it through a user customed sketch symbol and I read somewhere that up to Inventor 2014, the welding symbol was not accessible through API. My questions are:
1) Is it true that up until Inventor 2014 the welding symbol cannot be accessed through API? Does the Inventor 2015 do the job?
2) Is there another way other than using a sketch symbol for the weld?
Thank you
adam.nagy
Autodesk Support
Autodesk Support
Hi John,
It's easy to check if an object is supported by the API:
http://adndevblog.typepad.com/manufacturing/2015/05/is-this-object-supported-by-the-api.html
Unfortunately, it seems like it is not supported yet. 😞
Using a skecthed symbol might still be the best workaround.
Cheers,
Adam Nagy
Autodesk Platform Services
