It would also be REALLY great if when doing a DERIVE that all members of the tree, regardless of visibility, could be selected in the new part. Example:
This is the part I am trying to derive from. Notice it has a solid, and a sketch that is not currently visible, but exists.
This is the part I am trying to derive to. Why should the sketch not be a selected option?
Please, please don't make me have to open the object, turn on the sketch visibility, and then save it, then attempt to rederive my object, only to have to turn off the visibility after the whole thing is done again.
This involves too many clicks and steps. I *should* just be able to select the sketch.
Visibility != Enabled. If you want to allow the ability for objects to have features that are hidden from a derive operation, modify the behavior so that it is hidden by unchecked "enabled" instead of "visible".
