WikiHelp Browser Configuration
Provide a means in Inventor for users to configure browser access to the on-line Inventor WikiHelp.  Currently, if firewalls do not allow anonymous access to the hosting service (currently Amazon  Web Services) for the Inventor WikiHelp, there is no recourse.  If the application would allow configuring a proxy server for this purpose, users could access the most current help instead of waiting for the browser request to time out before reverting to the local static help file, if installed.
Sam B
Inventor 2012 Certified Professional
Inventor Professional 2013 SP2
Windows 7 Enterprise 64-bit, SP1 & IE 9
4 Comments
mrattray
As a work around, see this link for configuring Inventor to use offline help by default: http://beinginventive.typepad.com/being-inventive/2011/05/using-the-inventor-2012-full-help-even-if-...
SBix26
That helps a little, but better yet would be the ability to add proxy information in that XML file so that we could use the on-line help.
Sam B
mrattray
You're right, but I think if you could access the online help you wouldn't want to anymore.
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. The product team continually reviews this forum aiming to deliver in the most impactful way we can based on voting. We also regularly examine the list to make sure it reflects the most current Ideas. As part of this process we archive old Ideas that haven’t received broad support. This ensures there is room for new Ideas to be reviewed by the community and for the most relevant and meaningful ones to gain votes.
This Idea is archived because it's been on the board for over a year and hasn't received many votes. If you want to raise it again and try to gain more support across the community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups can help convey concepts and generate more votes from other users. If you have questions or see a connection between this Idea and others that should be accounted for, please let us know.
- INV.IdeaReview
