This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Welding feature in .ipt files
Greetings,
It should be possible to add weld feature in .ipt files. For example sheet metal part folded on all sides, requires welding in corners. I should be able to see that in .ipt format.
Thank you.
2 Comments
WillL84
This would be great. Currently I manually make sketches for the weld fillets for sheet metal
mikeh4
Not to deter from the wish, but you can derive the IPT into an IAM and add the welds there and utilize both IPT and IAM in the IDW.
Regards
