Tube and pipe API
Tube and pipe API
I would like to convert a standard part to a tube and pipe part like a fitting for example. In the UI you would chose Author->Tube and Pipe and then select a working point and an axis and there you are. This is currently not possible using the API. At least it is not possible without any user interaction. But i would need this to be fully done automatically.
1 Comment
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
