Fix the sketches for bent segments. Sweep segments don’t have constrained and dimensioned sketches so the Change Size on the pipe doesn't produce any results until you manually constrain and dimension the pipe sketch. The time required to do this makes it almost impossible to work with.
@dan_szymanski
