Create smart components from components that you use frequently that require the addition of associated components and features. Examples:
- A connector with mounting screws, nuts, screw holes, and a cutout
- A motor with bolts and mounting holes
- A hinge with mounting screws, screw holes, and recess
Solidworks has this feature and its fantastic.
It would be amazing if Inventor had this, if I could place a part I require into an assembly and the bolts required to fix the part go inautomatically as well as the holes & or cutout required to mount the part are created in the associated parts it is to be constrained to.
Why doesn't inventor have this? I can't believe no one has requested this.
