Selection in drop-down to change current dimension style
Currently having issues with changing form a decimal format to an architectural format for a single drawing. There should be an option where you right-click on a dimension and you can change the style for it to whatever you want.
There is currently an "Edit Dimension Style..." option but all it does is bring up the styles editor and there's no way to change the style for that dimension.
1 Comment
swalton
My usual workflow is something like this:
  1. Make sure there is a dimension style in the drawing document or style library that meets the new requirement.
  2. Select all the dimensions I want to change (Try Shift-RMB and the Select All Inventor Dimensions)
  3. Go to the annotation tab and use the style pull-down to select the new style.
  4. Inventor will apply it to all the selected dims.
You might try the Copy Properties command in the RMB menu, if you want to make a few one-off changes to specific dims.
