Run i-logic rule on inventor startup
Simpel as the header already shows.
Make it possible to run a I-logic rule on inventor startup.
2 Comments
pasi.annila
I think it's pretty dangerous if inventor crashes because of ilogic code.
At least you need a way to start inventor without Ilogic or there could be "a start parameter" to allow Ilogic on start.
Yes,
That is right.
I am preferring add ins instead of I-logic code.
But I am asking this because some people here on the forum want the flexibility of an add in and the use of I-logic.
My opinion is, if you want to do simple coding I-logic is not that bad.
But when the coding (in the document) needs a modification you are lost I think!
If the coding becomes more complex it is easier to use add- ins for inventor.
Actually when you are start programming and are familiar with I-logic it is not the complicated to create your first working add-in.
Benefit of it is:
  • Add-ins are not document based. (revisions can be made easily).
  • you can use the complete API. (application events; UserInput Events; etc )
  • You can easy use other DLL files.
  • and many others.
So basically it is a unknown question of I-logic users I think. (Can an I-logic code be started on inventor start-up?).
And this idea/solution would help them.
