Rotation increments in view and look perpendicular to a plane
There any possibility of adding a feature to Inventor which allows you to spin the view orientation in increments using your cursor keys? The angle of the incrementation to be set in options - eg 5 degrees, 10 degrees etc...
Also could it be possible to add a setting that allows you to view perpendicular to a plane - not just look at a plane?
1 Comment
This tool is available.
For questions regarding workflow and troubleshooting, please use the form below:
https://forums.autodesk.com/t5/inventor-forum/bd-p/inventor-forum-en
