Retain default row for an iPart or iAssembly
At present the default row in an iPart or iAssembly table is changed when a different member is viewed in the factory. It would be great if we could change between members within a factory without causing the document to become dirty or changing the default insertion table row. This is particularly noticable when opening the factory via an inserted member where Inventor switches to the member row and requires checking out the factory from Vault.
Preventing the factory becoming dirty when switching rows is probably difficult to implement, but even retaining the default row would be beneficial. We would continue being able to set the default row while editing the table. As well as retaining the default insertion member, it could simplify the dependency history of the factory in Vault due to fewer changes of the default row over time (assumes the document is saved for check-in using the default row, rather than the currently viewed row).
cadull
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
