RE: USER INTERFACE
RE: USER INTERFACE
Whenever I turn on the visibility of multiples parts in an assembly the work planes in the parts are also keep visible so to toggle off those parts i need to go to every e component in the assembly. It keeps frustrates me every time whenever I turn on the visibility of those parts. So it will be great to see at the model browser with the new subdivision named work planes were I can able to turn off once at a time.12.jpg
1 Comment
DRoam
There are two things going on here:
1. When you turn off the Visibility of a Part and then turn it back on, it's being reset to the Master "View Rep" which contains everything. This forces you to re-associate it to the proper View Rep. You can vote for this to be fixed here: Maintain Design View Representation when turning Part Visibility on/off.
2. Once you're using the appropriate View Rep (usually "Default"), there might still be a bunch of clutter in that View Rep. You need a way to clean that up and hide all the work features in that View Rep. You can vote for that here: work plane visibility
