Can we please have a new configurable in the Application Options to handle default Open behaviour? If your workspace is such that your models and drawings are saved into separate folders, you're constantly wasting time with excess clicks to travel to the opposite folder locations (from model space to drawings, vice versa).
A configurable setting within Application Options would be amazing; some considerations which I think are beneficial:
- Always open to Project file default location (top level or somewhere else).
- Open last opened file location (current behaviour, I believe, which remembers the location of your last opened file via this interface, and defaults there).
- Open current file location (ie if you switch to a drawing, then Open file, it defaults to the folder that your active drawing is saved, allowing you to open other drawings that sit alongside your current one quickly).
