push revision to model from idw
in some manufacturing situations or business systems that detail one part one drawing it is often required that the part (or assembly) need have the same revision letter (in the model iProperties) as the idw.
situation 1. to use the idw rev table functionality it is necessary to first revise the idw and then to ensure that the model has the same new revision letter that the IDW obtained from the "Add Revision" function.
or
situation 2. to use the model iProperty rev letter you need to do a bit of manual handling afterwards in the idw revision table, or one or two other things that can be used instead of the inventor rev table.
to save time, i would like to see an option in the document or application settings, that when selected would serve to allow the iProperty (ie latest revision letter) in the idw to automatically always be pushed back to the model as part of the "Add Revision" function when it is fired in the idw.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
