Prompts too hard to find, create prompt#
The list of prompts have gotten too exhaustively long  to find and read them all to find the coordinating prompt to turn off (or on)
Please add prompt numbers and display the prompt number in the pop ups. THEN you can coordinate the number to the list found in Application options.
(or we complain to Autodesk that the prompt can't be found in the list and to please add it so we can turn it off, 😁)
4 Comments
dwweekly
This has got to be the most meaningless prompt!
If you are trying to save , you know it has to save in the "Master" (primary*woke culture*) position.
Why give a useless prompt?
BTW , I can't find this useless prompt to turn off in the list
dwweekly
Could we get this prompt chosen to turn off in the next update?
If you are saving , obviously it must revert to Primary!
Patrick.Gamber
Agreed, this finding prompts that have been adjusted or need to be adjusted is difficult,
add an ability like right click, show find panel. so we could then type in keywords to filter the prompt list
hithere8
I suggest 2 options:
- add a search box on the top of prompt dialog box; when a user finds some info about the prompt online, it will be easy just to search;
- split the prompts into sections, then it will be easy to navigate.
Technology Administrators
