Ports under the Hole command
A number of years ago Autodesk added Taper Tapped Holes to the Hole command, I would like them to do the same thing with Ports.
I know currently we can add the ports to a part using the insert iFeature but if you made a mistake or things change, you have to delete the iFeature, lost all the constrains you had to it, put in the new iFeature and re-constrain the parts that use it.
If it was under the Hole command then it would be simple as editing a hole.
Companies would also have the benefit of adding their own Ports to the table that was used to create the Ports.
1 Comment
philthalmann
A BIG YES to this one!
