Please Include Broaching in the Hole Command
I'd like the ability to use the hole command to create broached holes per ASME B18.3 with the hole note on the drawing something like:
Ø.26 MAX X .31 MAX
V Ø.297 MAX X 90°
BROACH 1/4 HEX X .25 MIN
(depth and countersink symbols as appropriate)
The reason I ask, is that the broach is formed by a tool not unlike a thread tap in the sense that one doesn't modify it on a daily basis to create a conforming part. It seems silly to put a toleranced, reference, or basic dimension on a hex feature that is cut by a purchased tool (that is always manufactured to the high side of the allowed tolerance to boot). A call out for the nominal tool size make a lot more sense to me. Calculating the allowed hole size and edge break is a chore as well.
I will probably make a tabulated iFeature for the immediate future, but a built-in solution would be awesome.
2 Comments
inv.ideareview
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so.
inv.ideareview
Status changed to: Archived
