Pattern Qty i-Logic Solution
Do you have patterns that consistently need to be reorganized based on configuration changes?  Why use Code to dictate qty when you could simply start a pattern with "Qty of 1" and then develop the rules from there?  I had a configuration that has complex rules for Qty changes in patterns and as I had spent hours and hours trying to chase the qty up and down, I realized if I made my template with just qty of 1 it created a suitable and yet more effective environment for configuration edits.  Sometimes there can be hundreds of components in a pattern, but why make the code for all of these if you only need it for one configuration?  Start at 1 for the pattern QTY, and watch your code shrink and your models stabilize as you can suppress that pattern much easier......
1 Comment
rob_bolter
You can use "ceil(isolate(d120/200;mm;ul))" in the qty box. Obviously replace "d120" with your dimension.
d120 - Length of the pattern
200 being the pitch
Use curve length then in the drop down
