When dimensioning, once the "Edit Dimension" box pops up is it possible it could be altered so that you could simply start typing the name of a known existing named parameter?
Better still, could you introduce a non-case sensitive combo box so that if you type, for example, "F" or "f" it would list all parameters that began with both "F" and "f"? Typing more of the Parameters letters could narrow the list further until you are potentially left with the parameter you were after, this could then either be clicked or selected by hitting "Enter".
It would also be good if this combo box (with less mouse clicks) approach could be integrated into commands such as Extrusion. In this situation you could immediately start typing the Parameter you were after in the "Distance" boxes.
