Hi Autodesk,
I'm creating lots of full parametric models including iLogic with hugh parameterlists and especially lots of userdefined parameters. I need to test the params very often. Therefore I have several wishes / ideas:
keep the sorting e.g. sorted by key/parameter name - or better add a special column to memorize the sequence
Currently my workaround is numbering the comment-field and start sorting each time by the comment-column. If my models getting more complex it is not very handy, especially if next comments needs to be added.
With a special sequence-column it should be possible to
a) add numbers by hand
b) use the current sorting and do an automatic numberization (similar to partslist numberization)
Regards
Kay
