Other symbol to new section view feature "enable/disable" section
Hi Autodesk,
if a design view contains a section the user normaly sees this while activating the view. But if a design view contains a suppressed section there isn't a hint, that a view already includes an existing section but deactivated. OK, there will be a hint, if again the section view command is started - but nobody reads those nasty hints... 😉!
Especially, if an other user opens an assembly with those "hidden" section views this can cause question marks!
IDEA:
  1. add next symbol beside the view, which contains a section view
  2. No section view inside = no symbol
  3. suppressed section view = greyed out (or stricted through) symbol
Cheers
Kay
