When I create a construction line to be as a guide for my object line (they overlay each other in parallel but have different lengths) The problem/inconvenience occurs when I try to select the object line to dimension, delete or apply constraints; the longer (Typically the construction line) line gets chosen first. Yes, I can hover over the line to choose what is below, but shouldn’t by default the visible/object line be the first pick. That would be great if you implemented this with future inventor programs.
Thank you,
Your users
