Could you make it so when you have a stack of balloons you can attach a note with a leader to each balloon individually? Currently it only allows you to attach the not to the top/middle/bottom of the stack, but if I have a stack of 4 balloons and I want to specify that one of the parts is included twice in that stack there is no way to connect a note to a specific balloon in a stack, so if you move the stack around the note doesn't move with it. The best work around I have found so far is doing the not with the leader and then hiding the leader, if I do this then when I move the whole drawing view around on the page the text will follow, but if I move the balloon stack itself the text does not follow. If there is only 1 balloon and not a stack then attaching the not with the leader works great, so it would be nice if they could have the same function with a stack of balloons.
