[Multibody] - Improve Split solid tool - Extend option
at the moment if you use the split tool for this case:
You obtain this cut, that can be unwanted:
and these 2 solids:
________________________
I would like this option:
And obtain this:
And these 2 bodies:
Thanks!
3 Comments
Andrew2803
I know it may be  nit-picking, but you can "distract" cut-direction by just complementing your cut-tool sketch with a 90 degree bit.
Then you straightaway get just 2 split bodies instead of 3:
admaiora
Hi Andras,
thank you.
I know this workaround, and this is only a model simplification. Not all are so simple.
The idea is right to avoid this workaround.
Hi can you make a screen cast?
