Mouse wheel to increase/decrease value of a dimension
Users would like to have the possibility to increase/decrease values of dimensions or other dimensional input via scrolling middle mouse wheel button.
23 Comments
cbenner
I think this is a really bad idea... just use the key pad.  IMHO
JBerns
This could be a challenge. At what precision would it increment? First, second, or third decimal place? Ones, tens, hundreds?
Curtis_Waguespack
I can immediately imagine the errors this would create when a user doesn't realize the focus is still in the dimension input box and spins the mouse wheel trying zoom in or out. ( I feel like Inventor had this issue with Assembly constraint offset values at one point years ago, and I was fixed?)
If this were implemented and the user didn't realize the cursor focus was in the dimension input, spun the wheel trying to zoom, and the value increased from let's set 2.5cm to 18cm the user would catch it, be frustrated, but fix it.
However, if the accidentally increase was from 2.5cm to 2.9cm, the user might not catch this, and parts could get manufactured incorrectly and this "Mouse wheel to increase/decrease value of a dimension" idea becomes extremely costly. After this happens a few times the user's attention to detail is being questioned and the their performance review is negatively impacted.
For those reasons, this idea should not be implemented, or at least only implemented with extreme caution.
JBerns
Curtis,
I agree that this could be a problem if implemented. I was trying to point out the technical challenge of implementing the suggestion.
Jerry
jtylerbc
I'm with Curtis on this one.  Seems like setting users up for errors.  I can't imagine a circumstance where you would be using Inventor on a computer with a mouse and no keyboard, so I don't really see a use for this that outweighs the potential it has for causing problems.
DRoam
I'd tend to agree with you all that this could be a dangerous functionality. I think if it were implemented, the best way to do it would be like this: It only works immediately after you've selected or dragged one of the "handles" that appear when you're modifying an Extrusion, Revolution, Fillet, etc. And there would have to be some obvious visual indication, unlike there is now, that the handle has been selected. Then, this scroll functionality would feel more like moving the handle than like changing the value specifically.
Again, though, you would still have the issue of "how much" to move it by as JBerns mentioned. Maybe in rounded increments of some percentage of the visible graphics area would be a good starting place.
Still... this seems more like a gimmick than anything else. Inventor is a professional software, and professionals generally enter precise values, not drag things around until they look nice. Maybe not always, but generally.
ljordan
I agree. This could cause some unintentional dimension changes.
It would be nice though for section views in the assembly.
That way you could look at a front view and incrementally step the cut plane deeper into the assembly.
JBerns
LJordan,
You can do this already. While creating the section view, hover your cursor over the offset dimension edit box. Scroll the wheel to increment the offset distance. Right-click outside the edit box to set the step increment.
Jerry
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
dwweekly
just make it more like solidworks!!!....
I will say that because I have paid my dues in Inventor. It should be better in EVERY way from solidworks by now!
It/they had it in 2007 and I have been designing in Inventor since ver10 and MDT before Inventor's workable maturity @ ver10 . I have been wait on that and copy and paste context menu in the dimension boxes. Get with it Autodesk!
How bout those English numbered drills too, and magnet Osnaps! Really? I'm getting greyer!
roland.schaal
Community Visitor
This would be a great feature. And when holding down shift it would increase/decrease 10x
Hi there,
I agree, would be a great feature!
Very useful in combination with shift to increase/decrease 10x.
Very useful to see the effects on other geometry when changing values, much faster then typing other values.
Very useful for quick sketch based motion analysis.
Coming from 12 years SolidWorks, you only miss something when it is no longer there, and don't know what you do not know.
Greetings!
mpugmire
Community Visitor
PLEASE add this feature! It is my most missed feature from Solidworks, a true game changer when I discovered this tool and the easy way of tuning the increments.
As a designer, tools that allow for fluid adjustments to find the right proportion are incredibly powerful workflow tools. If I'm trying to constrain a sketch to allow quick editing and I want to explore 3-4 different dimension, it's a lot more work to punch in 3-4 different values on a keyboard for each variation, when it could be a simple scroll up or scroll down.
drew_bell
Totally agree that the shift for 10x scroll would make this feature so much more useful. I'm another recovering SolidWorks user. I work in consumer electronics, and I'm constantly going back and forth between PCB component scale (0.1mm increment) and hand-held device scale (1mm increment). Having that shift option to switch between these is something I miss intensely, especially for sectioning. Setting to one of these would either be too slow or much too course.
At least I know how to change the increment now thanks @JBerns. Right clicking OFF the box wasn't intuitive; I had tried right clicking ON the box. These settings would be great to have in the DISPLAY tab in Application Settings.
jonathon_crowe
Observer
Please add this feature!!! It is stock standard in many other software and despite what others say above, it does not cause errors and simply saves time. it could even be off by default if that truly is a concern, although i dont see how that argument could be made if it is made obvious enough through ui highlighting of the input box
Jacques3GSC6
Observer
6 years down the line and we are still asking for it.
Don't believe the neigh Sayers, they will all grow to love it.
They don't know what they don't know;
They don't even know that they don't know what they don't know 🙂
Please add this feature... Its one of my favorite features in solidworks and inventor can surely copy it by now.
Its a game changer
Stop opposing change and just go with it already, Please
nvotrader
Community Visitor
please add this feature
Jacques3GSC6
Observer
YES PLEASE
drew.porter
I would also love this feature. Please consider adding it. or at least increase/decrease arrows so I don't have to take my hand off the mouse to enter a dimension.
