There are a few ideas in here, all relating to balloons and parts lists.
First:
Allow users to snap balloons at certain angles (angles could be set by the user) so that we can have them be vertical, horizontal, at 45 deg. angles, etc. As an engineer, it drives me crazy when I see a jagged line in a drawing when it should be straight, but there isn't a way to make them straight? Why not?
Second:
Allow users to snap balloons to underlying sketches. I have a model that is exploded in an isometric (ish) view and I've inserted a centerline from the annotation tab. Using IV's built in Auto-Balloon feature doesn't work for me here; lines go absolutely everywhere. I want the balloons to be in a nice pretty row parallel to the centerline of my explosion. If I create a sketch and project the centerline, I can offset it as a guide to place my balloons, but there is no way to actually snap them to the line (but you can do it when adding leaders?).
Third:
Allow users to switch between Structured and Parts only within a drawing without making us delete parts lists, all of our balloons, etc. It's a huge pain to switch between the two and it shouldn't be. Each balloon and parts list that is placed within the drawing should allow you to select what BOM type it is referencing and you should be able to switch the reference when you want to.
This is a really old issue that people have complained about. There is a forum thread linked below (from 2010!) that talks about this issue c'mon Autodesk...: https://forums.autodesk.com/t5/inventor-forum/how-do-i-change-bom-from-parts-only-legacy-to-structur...
Fourth:
There is no reason why you shouldn't be able to have two parts lists within a drawing - one that shows parts only and another that shows a structured view. I have a drawing right now that I need to list every part for, but we don't necessarily sell every part as a serviceable item. We sell service kits which come as a set of these items. To properly balloon and label these, I need two parts lists - one for all parts, one structured. I know there are work-arounds to get two different parts lists like I mention, but there shouldn't have to be a work-around. This also means that when I go to balloon, I have to manually override some of the balloons to list the sub-assembly instead of individual parts.
Fifth:
Balloon a sub-assembly with leaders going to every part. Our explosion diagram also help serve as an assembly instruction guide. We need a balloon for a service kit so have a leader going to each part within the sub assembly. This can be done manually now, but it is a tedious process. Additionally, when exporting as a pdf, it creates extra lines that do not look very good. It would also be nice to be able to edit the arrow head style for each of these leaders as a group, instead of individually.
