More dim text placement freedom
Is there a way to make the text for the 2.500 dim go in between the lines….without changing the text size? There’s plenty of room, and I can even get the text to appear there when I’m moving it for a split second, but it won’t stay.
Also, I find it difficult to place dims as illustrated below,,,,and after placing them, if I move them at all it goes back to the other way.
4 Comments
JoAnn_Hogan
This might seem like a obvious and silly question. Have you tried editing the dimension style?
Go to your manage tab > Styles Editor > Dimension > Text Tab
I found that when I change the following settings I am able to move my dimensions freely.
Please let me know if this helps 😃
Yes, I've edited the dimension style, however the settings you highlight(which is how mine is set) doesn't change any of the above issues, I can only get the dims to fit in the lines when I edit these settings (see below), however I don't want to have to fudge these settings, for this changes the fit and placement of other dimensions within the drawing, and particularly changing those setting to get text to fit in a vertical dimension changes things in regards to a horizontal dimension as well.
I'd just like it if there was a bunch more freedom in placing dims and their text. I guess....see Solid Edge. Heck, it'll let you put the dim text in between those lines even if the text itself is larger than the gap between the lines.
inv.ideareview
Status changed to: Gathering Support
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
