Model States & Multiple Flat Patterns
Although we can create model states within our sheet metal parts, apparently the flat pattern created is only of the primary model state part.  In some instances, we make a left or right hand version, yet as things currently are, the flat pattern will only apply to the one considered primary.  Some sheet metal parts may also include or omit certain holes or features.
The ability to have a flat pattern per model state version would be the best solution for utilizing model states in sheet metal parts.
2 Comments
amundt
Would like to add that this perhaps should be an option type situation. For example if it is just mild steel then I'll just use one blank and indicate on drawing to bend half qty one way and bend half qty the opposite way (for true mirrored parts) but if it is #4 grain stainless then I would need a left and right blank. Also I don't think Model States was really intended for sheet metal parts and can't necessarily handle the flat pattern/s but can't think of a reason why they can't come up with some version of this just for sheet metal parts, "Sheet Metal State" maybe, 'cause I definitely agree that having that left and right from an single part file is very handy.
bestek
My two cents to this issue.
Handling model states in flat patterns would be highly appreciable. We have different sheets with knock-outs where some are knocked out in different patterns or sheets with model states and single bending steps.
So for our afford it would be useful to assign one particular model state to the flat pattern to avoid mistakes in the shop floor.
