I came upon an issue when I sent dxf to sheet metal nesting software. For this matter, I use the Mark Tool to engrave the order number and part number of each sheet metal part. Before Mark Tool, I had a sketch with the text that was controlled via a User Parameter, then copying to flat pattern, and after the order parameterization, the text was converted to geometry.
I was happy when marking tool came out, since it makes this process very easy and faster. But then we saw that the text-to-be-engraved was seen by AutoCAD as geometric lines, instead of a "geometric" text. So the software does not recognise it as text to engrave and ignores it.
Would be nice to be able to choose if in the dxf the text is recognised as such instead of just lines.
