In the presentation, when moving the components apart in the rotation mode, selecting multiple components gives you the ability to rotate only around one axis. In the example below, if I would like to rotate simultaneously and extend many bolts around THEIR own axis, it will not work, because they will rotate in a circle and not each around their axis. Only one of them - selected by default firstly - will rotate around its axis.
I suggest adding an option to select the axis of rotation for each component.
